Home » Car Questions » 2000 Infiniti QX4 power steering issue
Infiniti QX4 2000 mi:203k Power steering issue. Working fine until I used 4WD. Now regardless of 2WD / Auto / or 4WD steering very hard.
1 thought on “2000 Infiniti QX4 power steering issue”
  1. 1. First thing to check would be the power steering fluid level
    2. Check to see if any extra indicator lights are on the dash. If there is you will need to have the codes read.
    3. Check underneath to see if you may have a sensor located on the steering rack that is no longer plugged in.
    4. Jack up rear of car and with it in 2WD but in gear and see if it tries to pull with the front as it may still be stuck in 4WD.
