Home » Car Questions » 1998 CHEVYS10 PICKUP HAVING TROUBLE WITH STEERING
1998 CHEVYS10 PICKUP HAVING TROUBLE WITH STEERING.IT WANTS TO WANDER ON ROAD,ITS BEEN CHECK OUT ALL PARTS SEEM TO BE OK. HAS FAIRLY NEW TIRES. WHAT DO YOU THINK
3 thoughts on “1998 CHEVYS10 PICKUP HAVING TROUBLE WITH STEERING”
  1. The Chevy S-10 is known for idler arms wearing out often, this would be one of the first things I would look at. You said everything was checked out… Did you have the alignment checked as well?
  2. Granted your steering linkage is ok check upper control arm bushings.negative caster will make your car wonder. especially that model.
