(chevrolet spark,year:2003, 800cc, engine :F8CV, mini MPV) P1500 starter signal circuit, my car difficult to engine starting. this situation if weather 20celcius cool and rain. if normal weather 30degree Celcius. my car no problem starter. i think my motor starter is good.
i have been change new accu ready 13,8 volt , 4pcs spark,clean distribution
i try : push and run to my car in first gear. my car is easy starting.
how to fix?
Generally if you hear a click and all the dash lights go away it is a loose connection at the battery or starter. If you hear one hard click it is generally the Starter needing to be replaced. If you several clicks in a row it is usually a bad battery. In your case i would be looking at the starter. The new one may be bad… it happens. Check for battery volts on the “S” terminal of the starter while someone holds the key in the “Start” position. if you see voltage, replace the starter.
how do i change timing belt 2002 trailblazer
