I have a 2002 PT Cruiser,and when removing the pasengers side drive axle,with no sign of leaking ,fluid came draining out. should this have happened,are the differincal and transmitiom connected
This is normal as the axle shafts connect directly to the transmission. There is no Differential like on older rear wheel drive cars. Once the job is done, check your transmission fluid level and top it off as needed.
