Home » Car Questions » 95 Chrysler LHS 3.5 liter engine
My car is giving me problems. I’ve changed a fuel pump and filter and oil sending unit and checked the spark plugs and wires. The car starts for likes for 5 seconds and then cuts out and won’t restart unless we let it sit. What else can it be? I really need this car to get to the doctors so please help. Thank you
1 thought on “95 Chrysler LHS 3.5 liter engine”
  1. Best thing to do would be to first determine if it has no spark and or no fuel injection pulse when it will not start. Most likely it is loosing spark and the ignition module would be the most common cause.
    Also if the check engine light is on, pull the codes to see what they are. This can be done yourself.
    Here is How to Scan Chrysler Codes
    Post the codes back if you need help determining what they mean.
