our trucks rear end went out, it was a GT4,373 NO possi, the one we bought from a dismantler does have possi. Will it still work in our truck?
Chevy rear end
Keywords:Rear End
Yes it will work as long as the gear ratio is in the 3’s (308,323,342,355,373 etc) and came out of a similar truck. You will need to set the gears up. Meaning it will need to be re-measured and shimmed.
The GT4 means 3.73
Rear End Ratio RPO Codes:
GQ1 — AXLE REAR, STD RATIO
GT4 — AXLE REAR, 3.73 RATIO
GT5 — AXLE REAR, 4.10 RATIO
GU4 — AXLE REAR, 3.08 RATIO
GU5 — AXLE REAR, 3.23 RATIO
GU6 — AXLE REAR, 3.42 RATIO
G80 — AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 — AXLE REAR, 4.56 RATIO
