Home » Car Questions » 2000 expedtion starter wont disingage after starting2000 expedtion starter wont disingage after startingApril 5, 2012starter wont disengage after starting?Keywords:ExpeditionStarter1 thought on “2000 expedtion starter wont disingage after starting” Freeautomechanic April 5, 2012 at 5:10 pm Could be a couple of different things.1) sticking key tumbler 2) Failing ignition switch 3) Bad Starter Solenoid 4) Starter not shimmed correctly if you just installed it.Comments are closed.previousMAZDA RX8next1999 jimmy rear engine knocking
