Home » Car Questions » MAZDA RX8
MAZDA RX8
IVE BROUGHT NEW SPARK PLUGS COIL PACK AND LEADS ALSO CHANGED MY AIR FLOW METER  AND ITS STILL MISS FIREING WHEN I REV IT  ITS LIKE BRAKEING GLASS IN THE EXHAUST AND A RUBBER SMELL
3 thoughts on “MAZDA RX8”
  1. It is possible that you have a bad fuel injector and it might be stuck open and causing the misfire and the smell. The smell from raw fuel being shoved into the hot catalytic converter.
  2. P0300 is a Misfire Code….
    P0171 MAZDA Lean Air/Fuel Ratio Bank 1
    Possible causes
    – Intake air leaks
    – Faulty front heated oxygen sensor
    – Ignition misfiring
    – Faulty fuel injectors
    – Exhaust gas leaks
    – Incorrect fuel pressure
    – Lack of fuel
    – Faulty Mass Air Flow (MAF) sensor
    – Incorrect Positive Crankcase Ventilation (PCV) hose connection
