Well, just that.. it is burning the oil. This can happen when the piston rings get worn or the valve seals wear.
Usually this occurs over time and can also be brought on by not changing the oil often or skipping oil changes all together.
The good news is, as long as you keep the oil level full you can drive the car without harming it any further. You can do this for as long as you like.
