Home » Car Questions » 2006 ford fusion2006 ford fusionMay 15, 2012Front blinker stays on, and some times key less entry wont work1 thought on “2006 ford fusion” Freeautomechanic May 16, 2012 at 5:08 pm Sounds like you may need to have the BCM – Body Control Module Flashed(software update) contact your local Ford dealer service department with your vin# and they can check to see if it needs the latest update.Comments are closed.previousOlds 98 Steering Column IssuenextDid my mechanic ruin my engine or is it really just a coincidence?
