2007 twin turbo lacks power when driving all vacuum pipes ok.various sensor voltages tested all seem ok must be missing something,need help Malone
Mil lamp is flashing at all times does not reset at all
First thing you will need to do is scan the engine codes. This will tell you which cylinder/s are having the issue and will help narrow down the cause.
