Home » Car Questions » Clutch problem
Clutch problem
i replaced clutch, fork, bearing, and slave. then master, then line.
Then pivot and another slave. had numerous attemps to bleed. had accoplish a good bleed once but then the slave broke so that was when the slave was replace, since then cant get the clutch to work
1 thought on “Clutch problem”
