Home » Car Questions » temperature gauge not working
My boyfriend has a 1997 ford mustang, v-6 engine. the fan quit working and the temp gauge started working abnormally. The first mechanic looked at it and said it was a fuse. Replaced  the fuse and said it was fixed. No. The second mechanic said it was the cooling sensor, Replaced the sensor said it was fixed and the gauge should be normal. No. Next mechanic changed the motor in the fan and the other sensor.Yeah the fan works but not the temp gauge. Still moving abnormal. The next mechanic checked it and replaced the thermostat. He said that should make the temp gauge act normal. No! Now the temp gauge doesn’t work at all. A new fuse, fan motor, two new sensors and a thermostat you would think it works quite well. Why now is the temp gauge not working? What all needs to be checked to diagnose why the temp gauge isn’t working? Please don’t say what all these other mechanics say and tell me not to worry about it. I’m sure if you travel a distance in your car you would want everything working correctly. Especially the temp gauge. Would really hate to blow out the engine.
1 thought on “temperature gauge not working”
  1. It sounds like in this case it would serve you well to a wiring diagram and check for open or shorted circuits. You may want to start with the temperature gauge sensor(not the engine temp sensor, they are different sensors), Using a meter test the sensor as you should have no resistance when fully grounded. If the sensor seems to be working then trace the wiring from the sensor to the gauge checking for breaks in the wire and eventually testing the continuity. if all of this checks out and you do have good battery and ground to the gauge and it is still not working, it may be time to replace the gauge.
