My wheel is locking in upside down. recently changed out clock spring and rack & pinion.
books do not trouble shoot this issue.
The rack will only connect in one notch, but what you have to do is have the steering wheel locked in straight position so when you install the rack you are able to align the front wheels going straight and then connect the rack to the steering wheel shaft in the correct position.
So that being said. You will need to attach your steering wheel in the only position it has, turn it straight, disconnect your rack, straighten the to front wheels and reconnect the rack so that the two front wheels and your steering wheel aim straight.
