Home » Car Questions » 1995 Lincoln Towncar1995 Lincoln TowncarOctober 3, 2012I have a 1995 Lincoln Towncar that will not turn over. Where is the ignition module on this vehicle?Keywords:No Starttown car1 thought on “1995 Lincoln Towncar” Freeautomechanic October 8, 2012 at 11:18 am The ignition module has absolutely nothing to do with a cars engine cranking over. The only thing involved would be the ignition switch, Neutral safety switch, starter relay, battery and the starter itself. http://freeautomechanic.com/starting.htmlComments are closed.previoussaturn went deadnext2002 Pontiac Trans Am
