Home » Car Questions » 94 buick no fuel
94 buick no fuel
i have a good fuel pump good relay and fuses checked grounds that i could find will run in park and on road then will just die then out of blue will start and run for 10 mn or 2 hours
1 thought on “94 buick no fuel”
  1. This sounds more like an ignition module problem than a fuel problem. Next time it doesn’t start, make sure you have spark. If you do, spray some starting fluid in the air filter and see if it runs. If it does, then you know for sure it is a fuel related issue.
    If you do not have spark, replace the ignition module.
    If you have no spark and no fuel injector pulse, replace the ECM.
