Home » Car Questions » Ford, 1999 Ranger, Multiple problems
I have a 1999 Ford Ranger, 3.0L V6, Automatic. Yesterday, ran fine. Today, first drive of the day, “abs” lite came on followed by flashing “O/D off” lite. Slow to change from 1st to 2nd gear. Speedometer doesn’t register and “check engine” lite illuminated. Any ideas?
1 thought on “Ford, 1999 Ranger, Multiple problems”
  1. The good news is, the check engine light came on. This means that a sensor that your vehicles computer monitors has failed or gone out of range. This is good because it is more likely that you have a failing engine sensor instead of a mechanical issue.
    You now have the ability to have the computer codes scanned to help guide you to the problem causing sensor.
    If I had to guess, I would look at the VSS – Vehicle Speed Sensor.
    This directly effects the speedometer, and if the computer doesn’t know how fast your going it would have a hard time knowing when to shift or work the ABS properly.
