I have replaced the booster, master cylinder, calipers, shoes & pads, and bled the system. Brake lights (ABS & BRAKE) are still on. Brakes still drag. What next?
Also, my speedometer works but my odometer doesn’t. I thought they were connected by the same cable.
Sounds like you either have a brake hose twisted or one that needs replaced. After test driving it, see which side is too hot to touch. This would be the side that is dragging and would need to have the hose replaced.
As for the odometer, the odometer might be bad itself.
