I would suspect your 1 of 3 things.
1) Tires
– If while driving at 15 mph or slower the steering wheel tends to move back and forth by itself then you have a busted belt in one of your front tires. Rotate them to the back and test again.
2) Brake Rotors
– Your brake rotors may be warped, any rotor that has more than .003 run-out is warped and should be turned or replaced.
3) Wheel Bearings
– Your wheel bearing may be loose or damaged and may need to be adjusted accordingly.
The above is based on a 2WD truck, if it is 4WD you may need to jack up the front end and check your ball joints as well as the above mentioned.
1) Tires
2) Brake Rotors
3) Wheel Bearings
Front Brake Rotors warped.
