Home » Car Questions » 2005 rover 75 18t
2005 rover 75 18t
hi, have just noticed the trip stays illuminated when switched off and key removed. also, the on board message centre and trip computer have stopped working i.e no display at all. can you offer any advice to resolve this ? many thanks. phil
1 thought on “2005 rover 75 18t”
  1. First you say the trip meter stays illuminated, this is normal. Then you say the trip meter stopped working and has no display…..
    Check your fuses first, if all your fuses are good, you will need to check the connections at the back of the display panel, if these are good? the next step would be to replace the display panel.
