Home » Car Questions » 1994 ford ranger pick up truck
recently my truck began to spurter, hesitate, and jump when i’ driving; so, what’s the problem?
1 thought on “1994 ford ranger pick up truck”
  1. Most common reason for the issue would be an ignition system breaking down or failing. This could be any part of the ignition system. Spark plugs, Plug wires, Coil, or ignition module. Examination and or testing would be required. If the check engine light is on, Extracting the codes would be the first step in diagnosing the issue. Here is how to extract the codes without a scan tool:
    How to Pull Ford OBD I Codes
