WHERE TO REFIL AUTOMATIC FLUID TRANSMISSION FLUID? BY MISTAKE I REMOVED DRAIN PLUG TO TRANSMISSION PAN, INSTEAD OF THE OIL PAN AS INTENDED
In almost all cases, you would fill the transmission through the same port as you check the transmission fluid level.
After looking in the Owners Manual, The only information they show is:
Transmission fluid level
The transmission fluid level does not need to
be checked. If you notice transmission fluid
loss or gearshifting malfunctions, have an
authorized Mercedes-Benz Center check the
transmission.
and on Page 334:
Automatic transmission
GLK 35026 9.5 US qt (9.0 l) MB ATF
GLK 350 4MATIC 9.5 US qt (9.0 l) MB ATF
