I recently replaced the air injection check valve/solenoid and my truck stalls when the AC is turned on, I did have the battery disconnected while doing this if that helps.
05 Envoy SLE
did your truck stall before you replaced the air injection check valve/solenoid?
It is very possible that you left something disconnected when doing the replacement of the valve. Recheck your work if it didn’t start doing this until after you worked on it.
