Home » Car Questions » 06 PT CRUISER CHRYSLER
It was running fine tried to start it, it would not start all it would do is turn over and over. My buddy said it probably fuel pump he took air filter cover off and sprayed starter fluid in it almost started he said yep, so is it or could it be something  else he said he could not hear the pump when I turned the key on but I never could even when it did run. I don’t know what do
1 thought on “06 PT CRUISER CHRYSLER”
  1. Spraying fuel in the air filter is a common practice when diagnosing a no start situation. This helps to determine if the engine no longer has fuel or spark. If the engine does run when fuel is sprayed in then it would indicate that the engine is not getting fuel. However, it does not indicate if it is not getting fuel because the fuel pump is out or the injectors are not firing. In order to determine this, you will need to perform a fuel pressure test. This will allow you to see if your fuel pump is working or not.
