I have a 1998 Ford F-150 XLT 4×2 that needs a new under dash fuse box. I’ve found several fuse boxes with the same part number (F85B-14A067-AA) but different letter codes. The letter code for my truck is ‘B’, indicating it’s for a 4×2 pickup. The boxes I’m finding have a letter code of ‘E’, which is for a 4×4 pickup. Do you think the boxes are interchangable, or is there enough of a difference that makes you can’t use a different letter coded box?
If the part number is the same then you are going to get the same part in the mail. Same Part Number, no differences in the part.
