It could be spark plugs, coil packs, plug wires, etc. However if a cylinder misfire often enough it will set a code letting you know the exact cylinder. This will trigger the check engine light. If your check engine light is on, I would suggest pulling the codes first before going further. You are welcome to post back the codes if you need help with them.
