I would like to replace the distributor cap and rotor. Is this a difficult job or straight forward. Is it or will it be necessary to have to unbolt the whole distributor unit from the engine or just simply remove old cap and replace new cap and push on new rotor.
No need to remove the entire distributor. Just replace the distributor cap and rotor. Nothing to be afraid of. Just mark or keep track of where you wire go. I recommend taking one off at a time and putting it right on the new dist. cap. Firing order 1-4-3-6-5-2
