Home » Car Questions » 1996 dodge ram 1500
1996 dodge ram 1500
1996 ram 1500 5.9L 26gal tank—had to replace fuel pump–ordered online to save $$–pump came with sheet listing several wiring combinations in case wiring did not match–pump has 4 leads–truck harness has 6 leads–none of wire colors on sheet match actual wire colors on truck harness–am at a  loss as to what to connect to what…
1 thought on “1996 dodge ram 1500”
  1. You will need to get the right fuel pump for your make and model. Any local auto parts store should be able to match it up and get you one with in a day or the same day. They must have sent you the wrong one.
