Home » Car Questions » Jeep Grand Cherokee 1993
Cranks, wont fire up, not the fuel filter (replaced that) not fuel pump as it makes its noise in the tank I am also getting gas out of the port on the injectors. What now?
1 thought on “Jeep Grand Cherokee 1993”
  1. Now you need to determine if the engine is getting SPARK and or FUEL INJECTOR PULSE. So you will need to see if you are getting or not getting spark. Also you need to know if you are getting injector pulse.
    What I would do at this point would be to make sure you have spark, then spray some starting fluid in to see if she runs. If it runs on starting fluid, you know for sure it is fuel related. Next I would check fuel pressure.
    Post back your findings in the comments.
