Home » Car Questions » 05 envoy
05 envoy
can i drive the vehicle if i have removed the front differncial and axles
1 thought on “05 envoy”
  1. Yes, however with the front diff. missing the pinion bearing on the front drive shaft will no longer be lubricated properly. But should still be able to drive it. The best thing to do would be to correct the issue that you are having.
