I am working on replacing my water pump. I have gotten all the way to removing the timing chain tensioner to produce slack, then turning the crank shaft 20 degrees counter clockwise to move that slack over to the water pump so I can slip it off the water pump sprocket this did not work so how do you get slack on the timing chain around the water pump?
Home » Car Questions » 2001 nissan pathfinder 3.5 V6 4×4 automatic
Keywords:achieving slack in the chain to remove the water pumpPathfinderremoval of timing chain ran water pumpTiming ChainWater Pump
You will need to lock one gear before you move the 20 degrees counter clockwise. Then remove the water pump. If you need step by step instructions please follow the Auto Repair Manuals tab to your left. Free submission link toward the bottom of page.
