A noise is one of the most difficult to diagnose without actually hearing it for yourself but we’ll do our best to help. If the noise is made on acceleration with the car being in park, I would look at the engine closely. Check belts and pulleys. maybe even spray a little WD-40 on the belt while it is making noise and see if it goes away.
If it only makes the noise while driving, I would look at you under carriage to see if maybe some of the plastic molding is come loos and rubbing.
Possibly jack the car up so both front wheels are off the ground and then have someone put it in gear while you listen.
Here is an great article that may help you with your diagnosis: http://www.freeautomechanic.com/auto-repair.html
Thanks for the Reply ill check it out thanks again
