Home » Car Questions » Vauxhall Vectra Y Reg 1.8
I replaced my headlight bulbs recently. The drivers side went in ok, but the passenger side took a little longer and unfortunately i started to take out the whole unit until I realised that you could just remove the fuse box in front of the battery then replce the bulb, but, in doing so have now ralised that the O/S Headlight beam is a lot higher then the drivers side. Therefore, I would like to know if you can adjust these without going to a garage. Thank You
1 thought on “Vauxhall Vectra Y Reg 1.8”
  1. If you have not messed with the adjustments then you shouldn’t need to re adjust them after replacing just the bulbs. Retrace your steps and make sure you didn’t leave anything loose that correct this. Make sure the bulb socket is seated properly as well.
