I have a 1996 Ford F 150 5.0 the engine starts and runs intermittently I have replaced the ignition coil and the ignition module. But the problem still exists.
First thing you need to do is to find out what it is missing when it decides not to start. You need to see if Spark is missing by itself or if it is also not getting any fuel and or fuel injector signal. Post back you r findings in the comments..
