1995 toyota camry
hi i put a motor on a 1995 toyota camry with a 2.2 engine the one i got out of the car had a crank sensor the oneI bought has no crank sensor the 1995 toyota camry came with two 2.2 engine one with a crank sensor and one with no sensor how can i start this car ?
1 thought on “1995 toyota camry”
  1. You will need to swap over swap over everything to the replacement engine that came off the old one. If there are no mounting holes then you will need to fabricate. The other option would be to obtain the EM and wiring harness and swap that out as well since one computer is OBD I and the other is OBD II.
