I replaced the fuel pump in my car due to it just randomly shutting down while driving. Also replaced the fuel pressure regulator. after installing the pump the car would turn over but would only start if sprayed with starter fluid. That’s the reason for regulator. The gas isn’t getting to the engine. It still won’t start. I’m a disabled grandmother and try to do as much as I can myself. No money for service station. What else can I do.
most likely your fuel injectors are not firing giving you a “NO INJECTOR PULSE” situation. Your fuel pump and pressure may be fine but if the injector isn’t firing it won’t matter. First thing to check would be the ECM Fuse. if that’s OK check your wiring to the ECM and then the ECM itself.
