Then check for power and GROUND at the fuel pump. Do you have a good ground connection as well as Positive? Use a multimeter and check continuity in the wiring. If you need a > wiring diagram <. Start at the fuel pump this way all the connections can be tested.Another trick I use for testing is to remove the fuel pump relay and apply power there. If you can hear the fuel pump run then you know your ground is good and the wiring from that point is good (anything to keep from crawling under the car is a good thing, lol)The next thing would be to swap out the relay, if thats good move on from there.
