HI I’M AMIN FROM IRAN . I HAVE A 1999 GRAND CHEROKEE LAREDO . 4.0 L, 6 CYLINDER. I HAVE PROBLEM WITH GEAR SHIFTING . I CHECKED IT WITH DIAGNOSTIC TOOL . AND CHANGED THE SHIFT SOLENOID . BUT STILL NO SHIFTING . THEN I CHANGED ECU . CHECK ENGINE LIGHT GO OFF AND HAVE NO DTC BUT STILL NO GEAR SHIFTING . HELP ME PLEASE
Home » Car Questions » 1999 GRAND CHEROKEE LAREDO 4.0 6 CYLENDER
With most transmissions, the fluid must be full and checked in park on a level surface with the engine running. If the fluid is full and dark, this is an indication of burnt clutches and will require a rebuild.
If the fluid level is full and pretty pink, your front pump may be out.
