Home » Car Questions » 95 GMC Sierra ext cab 350 4×4
Im replacing my tranny. Why wont the torque converter turn once seated all the way. Its like its stuck in gear. Is replacement tranny bad?
1 thought on “95 GMC Sierra ext cab 350 4×4”
  1. torque convertor must slide in, rotate and move in further. When you attach the transmission and it is flush, you should have to move the convertor toward the flywheel to bolt it up. If it is already tight when you cinch up the bell housing bolts, the convertor was not properly seated. it needs to move in two steps or it will not line up properly.
    Even in park, the convertor should be able to spin.
