Home » Car Questions » mercedes A150 56 Reg
The problem with this car is that it doesn’t start when it gets hot. When the ignition is turned on it gives a hick sound but doesn’t run and as it cools down a bit when left about 20 minutes, then it starts.
1 thought on “mercedes A150 56 Reg”
  1. I would suspect the starter and/or solinoid. To confirm,
    spray water mist on starter when it’s hot for about a minute and try to start car. Refrain from using too much water as you spray.
    If car starts after starter cooling, take starter apart and check any part that
    rotates (ie; bearings etc.).Check electrical contacts as well.
    Hope this works for you.
