My car will not start, it has a manual transmission. It started this morning and I killed it in reverse and tried to start it again but it wouldn’t start it clicked inside but would not turn over.
No Start Diagnostics
As it says in the article above…”BATTERY”
A bunch of clicks means a dead battery. One Hard Click means a bad starter. Yours is the battery. Now you will need to charge the battery or replace it, but it has to be fully charged in order to test it. Most likely needs to be replaced anyway.
But don’t stop there. Have the Alternator tested also.
