Home » Car Questions » 1984 Subaru gl wagon 1.8 ltr
Car died while driving. I slowed to turn car, sputtered and died. Now it will start when cold then dies. Will run a little longer if throttle is held to floor. Can smell gas and seems to flood engine. I changed fuel filter, cap, rotor, air filter, PVC and still starts when cold then seems to flood out and die. What should I check next?
1 thought on “1984 Subaru gl wagon 1.8 ltr”
  1. Sounds like a c failed ignition control module. The symptoms you described are that of a bad ignition control module. Quite common for this year of vehicle. I would replace it and test.
