Home » Car Questions » 2003 ford explorer awd 4.0 engine
new battery new alternator,alt. is charging now,when i remove the heavy 12 volt output wire from the alt.i get no red battery warning light on the dash, and i did not get a warning when the alt went out the day before,,just the dial volt meter gauge went to lower voltage,got stranded,thanks
4 thoughts on “2003 ford explorer awd 4.0 engine”
  1. First thing I would do, Turn key to “ON” position(not “START”) and look at the dash to see if the Battery Icon illuminates. If it does not, time to check the bulb/led in the dash or just keep an eye on those gauges.
    What happens when you disconnect the little wires form the alternator?
  2. yes i have a battery icon that lights when the key is turned,then goes out when started,i did not try disconnecting the smaller wires,i would think i should have a warning when the alt is not charging,thanks
  3. I disconnected the plug with the two smaller wires from the alt. and the battery icon light came on ,thanks
