Home » Car Questions » 2007 Dodge Mini-van 3.3engine
Where is the PCV valve located on the engine exactly (a picture would be very helpful) and is it the type with a rubber gasket around it?
1 thought on “2007 Dodge Mini-van 3.3engine”
  1. The PCV valve contains a spring loaded plunger. The plunger meters the amount of crankcase vapors routed into the combustion chamber based on intake manifold vacuum.
    screws right into the valve cover of the engine.
    2007 Dodge Caravan 3.3L PCV Location
