2005 Dodge Dakota Quad Cab
I have a stock rear end and would like to replace it with a limited slip differential rear end, can the existing rear end be removed and a oem limited slip rear end from a similar year vehicle be replaced with out modification?
1 thought on “2005 Dodge Dakota Quad Cab”
  1. Yes, you can swap the entire rear end form one vehicle to another of the same year, make , model without issue unless it is a 4×4, then you have to make certain the front and rear gear ratio’s are equal.
    Keep in mind that if the gear ratio is different that the speed-o-meter will not read the correct mile. Make sure the gear ratio is the same if this concerns you.
