Home » Car Questions » 2001 Oldsmobile Aurora
My drivers side window is the only window that I can roll up and down.  Also the door locks just work on the drivers door using the key fob.  Could this be a fuse or something wrong with the master control?
1 thought on “2001 Oldsmobile Aurora”
  1. It is quite possible that there could be an issue with the master control but the most common reason would be a break in the wiring where the drivers door hinges. You will need to remove the master control and with a test check to see if power is leaving the switch to the passenger windows etc. and if it is you know the switch is good. trace the wiring till you find the open in the circuit and repair it.
    If you need a wiring diagram, follow the Wiring Diagram tab to your left and submit a request. After all its free, so why not.
