The car has gone 1000 miles in four months. how often should I change the oil? also, the place I go for oil changes says synthetic oil should be used for my accord?
It would benefit the engine to change the oil at least once every season change (assuming you are not keeping it inside a climate controlled garage). This would remove any condensation that may accumulate in the crankcase. So once a year would be fine in most cases if your only putting 4,000 miles a year on it.
As for the oil, you need to use API – SAE 0w20. You may use Synthetic motor oil if it meets the same requirements given for conventional motor oil; it displays the API Certification Seal, and it is the proper weight.
Drain and refill, w/filter is 4.50 qts.
