Home » Car Questions » 97 chevy s10 4wheel drive Manuel transmission
Clutch is slipping can I adjust it
1 thought on “97 chevy s10 4wheel drive Manuel transmission”
  1. The Clutch on this vehicle is Hydraulic and is self adjusting. There is no adjustments that can be made.
    If the clutch is slipping then it is time to replace the clutch disc and pressure plate assembly.
    If you find it difficult to get the transmission into gear, the most common reason is a failed Clutch Master and or Slave cylinder assembly. I recommend replacing both at the same time and when possible, get the complete assembly from a dealership as they come pre-bled.
