Home » Car Questions » 1999 Chevy Cavaleir1999 Chevy CavaleirMarch 16, 2014Head Bolt TorcKeywords:cavalierhead bolt torque1 thought on “1999 Chevy Cavaleir” Freeautomechanic March 16, 2014 at 12:47 pm •Use the following sequence in order to tighten the cylinder head bolts:Tighten • Tighten the long cylinder head bolts to 63 N·m (46 lb ft). • Tighten the short cylinder head bolts to 58 N·m (43 lb ft). •Tighten bolt 1 to 63 N·m (46 lb ft). •Tighten bolt 2 to 58 N·m (43 lb ft). •Tighten bolt 3 to 58 N·m (43 lb ft). •Tighten bolt 4 to 63 N·m (46 lb ft). •Tighten bolt 5 to 63 N·m (46 lb ft). •Tighten bolt 6 to 58 N·m (43 lb ft). •Tighten bolt 7 to 58 N·m (43 lb ft). •Tighten bolt 8 to 63 N·m (46 lb ft). •Tighten bolt 9 to 63 N·m (46 lb ft). •Tighten bolt 10 to 58 N·m (43 lb ft). •Use J 36660-A to tighten all the cylinder head bolts an additional 90 degrees in sequence.Comments are closed.previouspeugeot, 107 active 2013next2002 Chevy Cavalier 2.2 L engine (the most common cavalier engine)
Tighten
