I have replaced the oil pump but still not getting oil from the pump into the engine. Getting oil from the pan into the pump. But it is not circulating through the engine.
The oil pump kit I have came with a spring, small slide piston and a cap. But they do not get installed where the pump is located. Oh, just a note the drive shafts for the pump is in working order. I have read on-line those parts go behind the timing chain cover.
Can’t find a Haynes Book that covers the 3.8 liter. Any suggestions what I can try before I have to take off most of the front engine. And is that spring assembly even located there.
Any help would go a long way. Web pages, diagrams and things to try first. Kinda at a loss on this.
If this is what your kit looks, I think you will find in the instructions it came with that you need to remove the black plug and swap out he piston and spring to change the pressure.
You need to make sure the oil filter is full of oil when you install it. You may have a restriction internally that is not allowing the oil to flow.
Removing the front cover of the engine was for older 3.8L engines, yours is not like that of a 1995 or older.
